Hi Dv
Are you referring to Hybrid Connect? This is a back-up service we provide, depending on the signal strength in your area, where if your broadband connection was down, your router would connect via the mobile signal of the Hybrid Connect.
Hi 👋
If you're looking to move to BT broadband but keep your current Sky phone line/number, you absolutely can do that.
🔹 Keeping your landline/number:
When you switch to fibre or digital services, you can usually keep the same phone number through digital voice/VoIP. This works even when switching between providers.
🔹 Who to speak to:
BT Business have a dedicated switching page that explains the process step‑by‑step and tells you how they handle broadband, phone lines, and number transfer:
👉 https://business.bt.com/help/article/broadband-and-internet/cancellations-orders-and-returns/how-do-...
[business.bt.com]
🔹 What happens when switching from Sky:
– If you switch broadband only, Sky will need to be notified.
– If you switch broadband + phone line, BT will contact Sky on your behalf and usually keep your number during migration.
[business.bt.com]
If you’re curious about how digital landlines work or the UK copper switch‑off, this guide is also helpful:
👉 https://www.which.co.uk/news/article/five-things-you-need-to-know-about-the-landline-switchover-and-...
