Hiya,
I had a wires only connection activated yesterday, but appear to be missing any sort of setup guide for what is expected configuration on my end.
All I have been sent so far is the non directly connected subnet information. I do not have a wan IP or info in order to setup a gateway/bgp link.
Is there any setup guide around?
EDIT: Product is the 1000BaseSX Leased Line, Wires Only
Do you have a BTB Smart Hub 2? And which broadband package do you have?
Oops, leased line, 1gbps, wires only
That is beyond my ken!
Try Googling
BT "wires only" "leased line"
Is this any help?
https://community.spiceworks.com/topic/2310170-bt-leased-line-ip-details-issue
Ye I found that,
After calling BT, they had just failed to provide a part of the information. Got it working somewhat now, but speeds are far below.
For history - here is a quick breakdown of how to setup the primary IP:
Here is the info BT Provide in an email:
IPv4 Non-Directly Connected Section
IPV4 Network Address : 224.xx.xx.93
IPV4 Network Mask : 255.255.255.248
IPV4 Next Hop Address : 78.xx.xx.139
Here is how you actually setup on the router
(external) IP Address: 78.xx.xx.140
Netmask: 255.255.255.254 (May display as /31)
Gateway: 78.xx.xx.139
Then route alias the additional network addresses via the primary network.
I also had to disable auto-negotiation and set a fixed link speed.
