BtBhub6 needs a ui speed up i find it slugish and slow
regchan
Member
BtBhub6 needs a ui speed up i find it slugish and slow and some times its not responding really my edge router is faster then this and also bt hub 3 was faster too
1 REPLY 1
RyanJames
BT Employee
BT Employee
HI Regchan
Sorry to hear you are having issues with the Hub6. For certain tasks, 3rd party routers may be more suitable - we do not support 3rd party routers however though, unless you avail of our Enhanced IT Support package, but if you know what you are doing in regards to set-up and service, 3rd party routers can definitely be a viable alternative.
If you are having any issues with your service as a whole I would recommend giving us a buzz on -0800 800 154 and we will happily check that out for you. 🙂
Regards
Ryan
