- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Im sure this has been hammered to death but im confused can I? if so how? put my hub into MODEM only mode.
I have another router set up working exactly how I want it the portforwarding our CCTV etc is just great. I have tried NUMEROUS times to set up this router and it will not forward as I need. We dont use WIFI so will turn that all off.
Help would be much appresiated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
under 'advanced settings' choose 'broadband' and then 'routing'
At the bottom of the page click on 'bridging' to select 'yes' then save your settings.
You then connect your router to one of the LAN ports on your BT hub.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
