Complete Wi-Fi Plus Disc: issue
ripple11
Member
Broadband recently upgraded and installed and extra discs to boost wifi seem to be working fine  on the allocated network and password.
However  I have set up, (as offered on the system),  a "guest wifi" from the "Hub manager" with new name and password. This guest network works near the main hub...BUT not it seems, from the extra discs in other rooms.
Any ideas why?
TIA
3 REPLIES 3
BethM
Administrator
Administrator
Hi ripple11
Guest Wi-Fi only works from the Hub directly, it will not work over the discs.
^BethM
ripple11
Member
Thanks for reply. It worked with the old Hub 2 I just had, so this is not acceptable. Who do I complain to please?
BethM
Administrator
Administrator
Hi ripple11
As per Clause 2.3.3 in our terms and conditions here: https://business.bt.com/content/dam/bt-business/pdfs/terms/broadband/BTL_BTE_Business_Broadband_Esse...
2.3.3 Guest W-Fi Users will only be able to access Guest Wi-Fi through your BT Hub and not through your Wi-Fi Disc or Complete Wi-Fi Plus Device (if you have Complete Wi-Fi or Complete Wi-Fi Plus)
If you wish to raise a complaint about this, I can do this for you but from what I've been advised by the technical team, there is no work around as it is not something the discs can connect to. Please private message some account details and we can discuss from there.
^BethM
