Broadband
Get support for BT Business Broadband and wi-fi products including hubs and BTnet.
Forum Posts
Frequently asked questions – Broadband
How do I do wiring checks?  If you’re having trouble with your broadband, we recommend doing some simple wiring checks to find out what’s causing the issue. The checks differ slightly depending on what socket you have. Here’s a link to the guide for ...
BethM by Administrator
  • 5052 Views
  • 0 replies
  • 0 kudos
Business Smart Hub 3 power supply
Had an interesting fault with my full fibre.    The Smart Hub 3 suddenly refused to connect.  Swapped it out with a new Smart 3 hub and had the same issue.  I was being lazy and using the same power supply.   However when I swapped to  a a new power ...
bobm by Member
  • 87 Views
  • 1 replies
  • 0 kudos
Bt smart hub 3 disks
Hi,  I just got a Business smart hub 3 , FFTP and 500Meg , If  I run a 20M  cat5e from the hub what sort of free space wifi rate (no walls)should  I expect if  I connect a new black Square wifi disk to it ?thx
Smarthub 3 not seeing MAC address
I have added a smart electric meter to my network, with MAC address 00:19:3D:0D:63:63. I can see the device on my ARP table, and on Advanced IP Scanner. but the Hub denies its existence. I want to set a fixed IP address for it in the hub, but without...
sjt01 by Member
  • 781 Views
  • 1 replies
  • 0 kudos
BethM - forum team, I need your help again please :-)
For the Mods,About 3 weeks ago, a car accident happened on a main road about 1.5 miles from my business broadband address.  This accident snapped the BT poles, and naturally severed all broadband fibre feeds to our entire area.  I have a BT business ...
Static IP transfer from copper service to Full Fibre
HiI had my BT business copper service upgraded to Full Fibre two weeks ago and right from the start requested my static IP address that I have been using since the old service was installed over a year ago, to be transferred over to the new service. ...
etocwel by Member
  • 851 Views
  • 2 replies
  • 0 kudos
New Broadband service over fibre
I called in to Sales to request a new BT Business service, broadband and phone. I made it very clear to the Sales rep that it was a "new" service i.e. there is no fibre to the building from the street (the building is not new, just the service is new...
Openreach extend or MUX
I have fibre to an out building on my farm, it is a long way from the pole at 230 M, I now want to move it an additional 20m into my house and the person who is going to use the out building will want to have their own BT service. Can Openreach splic...
