Login using ip address
DrMopp
Member
Any attempt to login with 192
168.1.254 gives 'bad gateway' error on mobile using either MSEdge or Chrome
11 REPLIES 11
BethM
Administrator
Administrator
Hi DrMopp
Are you trying to access your router settings? What router do you have?
^BethM
Yes, it's a BT Business Smart Hub 2
BethM
Administrator
Administrator
Hi DrMopp
Okay, and you're getting bad gateway when you go to 192.168.1.254? Have you made any changes to the router settings prior to this?
^BethM
No.
BethM
Administrator
Administrator
Hi DrMopp
How strange, what device are you attempting to access the GUI from? Are you using a VPN?
^BethM
Samsung S24 mobile.  I was using a VPN but when disconnected I am unable to connect to the Internet at all.
BethM
Administrator
Administrator
Hi DrMopp
Are you able to connect direct to the router on another device?
^BethM
Not really, entering 192.168.1.254 on my PC shows this screen, but no Router admin panel:-
BethM
Administrator
Administrator
Hi DrMopp
Strange, and it keeps doing that? I think we should get the Tech team to look into this, have you called them about this already? Their number is 0800 800 154.
^BethM
