We have fftp 300 the line is testing fine but we keep losing internet connection. The 3 green lights are on at the wall unit but the hub is flashing orange. When I go into the hub manager it says it is has a connection. We are also experiencing buffering in our lan connected streaming service. Could this be a faulty hub? If so how do I get a repacement
Hello,
It sounds like you're experiencing intermittent internet connectivity issues with your FFTP 300 service, despite the wall unit showing a stable connection. The flashing orange light on the hub, coupled with buffering on your LAN-connected streaming service, strongly suggests a problem with the hub itself. While the hub manager might report a connection, the flashing orange light indicates it's likely unstable or experiencing errors.
Best regards,
Tisha
Hi 55H
I would recommend doing some wiring checks for your equipment to see if that resolves your issue. If it persists, I would recommend raising a fault.
