Hello
I have a Business Hub 5 and I wanted to know whether it would be at all possible to use it on my home network? I understand that the main difference to the Home Hub is to do with the business hub using a Static IP address whereas at home I dont have this - would I need to change any settings etc?
Thanks,
Kel
Solved! Go to Solution.
Hi Kelso_
From my knowledge, with the Business Hub 5 you would need to change the login detiails that are in the Hub 5 form your business details to your home broadband details, other than this it will work on your home connection. You are probably best ringing the residential team to see exactly what these details would be - but off the top of my head it is normally your landline number follwed by @BTBROADBAND.COM - so for example "[email protected]". Again though, it would be best to get in touch with BT themselves to check.
Hope this goes some way to clearing things up for you!
Regards
Your friendly neighbourhood Raymo 🙂
Hi Raymo
Ah, thanks! That's ace!
Have a great day! 🙂
Kel
