VPN
Dsmack29-3
Member
Recently installed BT Business SH3 and looking to install a VPN to give LAN wide protection. Doesnt look to be much by way of opportunity in the GUI.
Does anyone have any recommendations. Trying to avoid installs on each device.
1 REPLY 1
Hello there @Dsmack29-3,
Setting up a VPN for LAN-wide protection can indeed be a more efficient solution than installing VPN software on each individual device. Unfortunately, it seems that the BT Business Smart Hub 3 (SH3) does not support the setup of VPNs when multiple routers are involved, or in configurations where a third-party router is also providing a VPN.
However, there are enterprise VPN solutions that can be installed on a single device, such as a router or a dedicated VPN appliance, to provide protection across the entire LAN. Here are some recommendations for enterprise VPN solutions that you might consider.
Offers high-speed routed site-to-site and remote access VPNs.
A modern solution that simplifies secure access to private applications.
A cloud VPN that provides secure remote access.
A business VPN solution with a focus on simplicity and security.
A well-established VPN client that offers robust security features.
Integrates with Fortinet’s Security Fabric to provide comprehensive security.
These solutions can help you avoid the need for individual VPN installations on each device and offer centralized management of your network security. It’s important to choose a solution that is compatible with your existing network infrastructure and meets your specific security requirements.
Remember to ensure that any VPN solution you choose complies with your business’s security policies and provides the necessary level of data protection.
Best Regards,
