Hi All
I have a second office in rural Scotland, and as you can imagine - whilst the views are simply delightful - the internet is soul-destroyingly slow. I know this cannot be helped given the location, but I was wondering where I can find an update as to when fibre will be available. It will be a glorious day in the office let me tell you!
Thanks in advance
Bob C
Solved! Go to Solution.
Hi Bob
Jealous of the views you have! I have family in the Highlands and its a beautiful part of the world!
I think I can assist you with your query. I used the Openreach checker here to find out when fibre was going to be made available in my area. It can be a bit vague, but it should advise you correctly. I think if you contact BT they have leased lines that you may be able to get also.
Hope this helps!
Kel
Hi Bob
Hope this helps!
Kel
Hi Bob
Kel is spot on - that link should keep you right! And if you PM me your line number I can check if we have any alternatives to give you faster speeds 🙂
Regards
Ryan
