3rd party access to text messages
Surjane
Member
Is it possible for a 3rd party to get access to my text messages on my mobile phone, download them and print them off without my consent or actually using my mobile handset?
15 REPLIES 15
RyanJames
BT Employee
BT Employee
Hi Surjane
Hope you are well! To my knowledge no-one can access your text messages without physical access to your SIM. If you need further support, you can find our contact information and faqs in www.bt.com/business/help
Regards
Ryan
Diana-Farad
Member
Thanks for the help! Very valuable explanation.
ryder8629
Member
Case 1: People: No person can access your text messages to 3rd party vwithout any kind of physical access...Hacking may be an option but meagre possibility in case of text messages.As no use of data in sms.
Case 2: Applications: Some applications have direct access to text messages,but they are all trusted sources permitted by google play store...And i don't see any reason to doubt google though
Thank you for posting something like this Thank you for posting something like this
jekky
Member
If you're on Android, Google Hangouts is the default for messaging with other Android (and Google) users. ... If you want a simple way to communicate with people between different devices, third-party messaging client make things easy. That's where apps like WhatsApp or Snapchat comes in
Enriquez451
Member
Thanks for the nice post
Omegle
Kaylie
Member
PetersonO
Member
End-to-end encryption means that messages are encrypted on the sender's device and only the recipient can decrypt them..Other user favorite chat apps including Facebook Messenger, Snapchat, Kik, Skype, and Yahoo Messenger only offer in-transit encryption, which means they could be accessed by a third party.
kelper
Guru
Do you suspect that someone has read your messages?  If someone had physical access to your phone without your knowledge, they could install some hidden malware.  State actors can install spyware remotely.
Lenard
Member
The app or service won’t be able to access any more info from your Google Account, but you may need to request that they delete the data they already have.
