BT ATA191 configuration
heeleyc
Member
Hello there.
This is further to an earlier post of mine where I was attempting to integrate a Bell system BT1 with the BT Business voice system.
I've now obtained from BT a Cisco ATA191 adaptor, however it fails to work with  the Bell BT1.
I have been able to confirm that this is due to the internal settings of the ATA191 needing to be configured differently.
As I understand it,  it is, in theory, a relatively simple job to access the ATA191 using its IP Address and subsequently change the settings.  Unfortunately I am also led to believe that the ATA191 is locked down by BT in so much as they have set an alternative password rather than the default.
I am in possession of a table showing the correct settings for the device.
So what is the best way forward ?   Can BT provide me with the credentials to access and then configure my device myself. Or can some kind Moderator  advise me as to who I can contact in order to provide them with the settings so that they can presumably upload them remotely?
I should dearly love to get this issue resolved.
Kind regards
Heeley Culton
1 REPLY 1
henry45cavil
Member
Because the ATA191 is locked down and remotely provisioned via BT's central Auto-Configuration Server (ACS) using the TR-069 protocol, any local modifications you theoretically managed to make would simply be overwritten the next time the device resyncs with the BT cloud network.
