My query is whether the base station must be connected to the router associated with its respective BT account, or if I can connect it to the router in our office under a different BT account.
Hi,
You should be able to switch the broadband the main base station is connected to without an issue. Calls will still connect to the handsets working off the other broadband.
Thank you
Adam
