Digital Voice
Marum
Member
I currently have an FTTP connection with linked Cloud Voice Express and it is up for renewal in January.    I'm not planning to move the broadband.
VoIP uses a Yealink base and handset - however usage is minimal  although some key contacts use it maybe once a month and getting them to change will be difficult and I need to also retain the number
The renewal I am being offered excludes the Yealink and relies on a Smartphone App which I am not too enthusiastic about.        So,  two questions.
1.    Can  I continue will the existing Yealink?
2.    Can I obtain the login details to allow me to migrate it to the Gigaset system my other numbers are linked to - obviously leaving the number with BT?
And anything else I need to be aware of?
3 REPLIES 3
BethM
Administrator
Administrator
Hi Marum
You can't use our Cloud Voice Express with 3rd party handsets. Did you get the Yealink from us?
^BethM
Yes,    BT supplied 2 years back
BethM
Administrator
Administrator
Hi Marum
Unless the renewal asks for the equipment back, you should be fine to continue on using it.
^BethM
