Fault Reporting Online?
BobbyDotGov
Member
Hi
Just wondering how I go about reporting a fault on the line? I don’t have any problems just now, but I rarely have time to ring in and just want to know in case anything pops up.
Bob C
1 ACCEPTED SOLUTION
Accepted Solutions
RyanJames
BT Employee
BT Employee
Hi there Bob
Hope you are well! To answer your question, you can report a fault online with your phoneline here. You can also find links there to our livechat teams who can assist you if you have any questions! 🙂
Hope this helps!
~Ryan
View solution in original post
1 REPLY 1
RyanJames
BT Employee
BT Employee
Hi there Bob
Hope this helps!
~Ryan
