Virtual Phone?
Kelso_SanDiego
Member
Hi
Not sure if this is in the right section, but does anyone know if i can obtain a (local) business number from BT but have it diverted to my home number or mobile? Basically this is so I can work at home without giving my home number out on the marketing materials. The business requires a local number also, as opposed to a 0800 etc..
Many thanks
Kelly
1 REPLY 1
RyanJames
BT Employee
BT Employee
Hi Kelly
BT Offer a service called Remote Call Forwarding. BT's Remote Call Forwarding (RCF) is a facility for transferring incoming calls to a different location. It is used when you has moved out of the exchange area do not wish to lose calls, or if the you wish to advertise a number from a certain area where you do not actually have a physical presence.
This is an expensive service, as you have a connection charge and rental of a number at the exchange, you would also incur some call charges. But you can other cheaper diversion features.
If you are interested in this service please contact us.
Kind Regards
RyanJames
