Hello,
I have recently bought a house that was previously multi-unit offices, I have gone through the process of change of use, and the property is now my home (after a lot of renovations – Grand Designs, eat your heart out!). The property has a lot of BT boxes / DP's on the outside, with some cabling to a nearby pole.
I would like to have these removed as they are no longer in use, would anyone have the correct details within BT please?
Thanks.
Regards
Bob C
Solved! Go to Solution.
Hi Bob,
To get the boxes and cabling removed from the outside of the house you would need to speak with Openreach as it is their cabling etc, if you call them on 0800 023 2023 opt 1, they can discuss it with you.
Hope this helps!
Ryan
Hi Bob,
Hope this helps!
Ryan
