Request Specific Phone Number
dmcdonald
Member
Hi,
I've tried searching but can't find anything that up to date.
I'm looking to obtain some specific phone numbers that are showing as operated by BT. None of them are in use.
Is there any way that we can request this?
We're currently a BT Business customer.
David
1 REPLY 1
RyanJames
BT Employee
BT Employee
Hi David
With regards to this one, if you call our BT Business Sales team on 0800 800 152, they will take a look at the numbers you need - if they find that the numbers are available they can order a new line or lines and port those numbers you need over to those lines. This is only an option if those numbers are showing as spare and not in use at all, which the sales team will check for you. 🙂
Alternatively you can PM me the numbers you are needing and I should be able to double check those for you also.
Regards
Ryan
