I just upgraded my broadband to full fibre and I’ve been given a hub and a Yealink DECT IP Phone (W73P).
I have been provided with my username and password by BT so I have swapped out the provided hub with my 7590 and everything is fine with it. However, does anybody know if the IP Phone can be used with the 7590? If it can, does anybody know what I need to do? If it cannot, can I just use a normal DECT phone connected to the 7590?
Hi,
The cloud voice express support articles can be found here BT Cloud Voice Express help and support | BT Business You can try the handset provided with your new hub of course but I can not confirm if it will be compatible.
We can only recommend you use the BT provided equipment and would not be able to support on any external equipment you have bought.
Hopefully a member of the community with be able to support on this IT enquiry.
Thank you
Adam
