HUB3 will not link to Advanced Digital home phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I've tried with two different handsets,
1- Press WPS button on Hub, blue light flashes, and flashes and flashes, phone eventually says "connection failed".
I have 3 of the Cisco desktop phones which work fine with the Hub.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@CANUK63 wrote:I've tried with two different handsets,
I have 3 of the Cisco desktop phones which work fine with the Hub.Any suggestions?
Hello,
It sounds frustrating to experience connection issues with your handsets! Here are a few troubleshooting steps you can try:
Reset Handset: Turn off and restart the handset.
Proximity: Ensure the handset is close to the hub when pressing the WPS button.
Interference: Check for any electronic devices nearby that might cause interference and move them away.
Update Firmware: Make sure both the handset and hub have the latest firmware updates.
Anyone else experienced similar issues and found a solution?
Does this help? Let me know if you need more detailed guidance!
Best Regards,
Joan Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi CANUK63
Are you a BT Business customer and is this a BT Business Smart Hub 3? You can only use digital handsets ordered and provided by BT Business if you're a BT Business customer.
^BethM
