Managed router to wires only
ScottWilko1
Member
Hi
We have a lease line that is supplied with a Meraki router.
My client is doing a server migration to Azure, and we need to change the service on the lease line to wires only and put the Meraki into "bridge mode"  We can then put a third party firewall on to create the VPN links
Is this possible on an existing agreement, or do we have to sign a new one?
Scott
1 REPLY 1
Conway
Member
The possibility of changing the service on your existing lease line and configuring the Meraki router into "bridge mode" would depend on the terms and conditions of your current agreement with the service provider.
Typically, lease line agreements allow for certain changes and modifications to the service, but it's important to review the terms of your specific agreement to determine if such changes are permitted without signing a new agreement.
It is recommended to reach out to your service provider directly to discuss your requirements and inquire about the possibility of changing the service to wires only and configuring the Meraki router into bridge mode. They will be able to provide you with the necessary information and guidance regarding the process and any contractual implications.
