I currently have a BT Business Hub with a similar setup, however the difference is
IP 1 > Router + Wireless Devices via DHCP > Hardware Firewall Using (IP 2) > Normal internal Networked PC's
I can only think it was set up this way to separate the ipads / phones from the normal business network and on the BT Business Hub there was a Business Network section that allowed you to assign a public IP to a particular device.
We are moving to a new site that cannot use the BT Hub and we are now using a Netgear DGND3700v2, i would like to use the same/similar config if i can.
Would anyone have an idea of how i might do this?
Hi there,
Maybe this answer will help?
