2701HGV-C Fibre router
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Is there a modern replacement for this router. I use BT voip service so the replacement will need to have a voip service on it. The existing one is becoming a bit problemetic and 4 years old.
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi homeelectrical,
The VoIP service that you have, do you connect normal phones to a 2wire adapter in to the back of the 2701?
If you do then you are only able to use the 2701 hub/router as the newer hubs are not compatible. If however your phones are VoIP phones and connect into the hub/router via etherner and the configuration is in the phone and not the hub/router then you can upgrade your hub/router to the business hub 5.
I hope this helps.
markp
0
Kudos
