550 Relaying denied
jbh
Member
Hi I have outlook 2007 configured to receive and send e-mails. I can send a test message without issue. However if I try to reply or send a new message from outlook, I get the message:
Your message did not reach some or all of the intended recipients.
Subject:    ......
      Sent: 10/08/2011 21:27
The following recipient(s) cannot be reached:
      '..... .....' on 10/08/2011 21:27
550 Relaying denied
I have inserted '.....' for the subject and recipient as this obviously changes for each e-mail.
4 REPLIES 4
JohnE
Guru
Thanks, jbh, for not having to have your post edited.  Relay errors (550) usually happen because:
1/ You are sending using a domain name which is not hosted by us nor listed on your account for mail relay
2/ No outgoing authentication enabled when the mail program in question requires it.
When it comes to outgoing authentication, we find that Outlook 2007/2010 generally doesn't work with it on our servers (Oddly, some installations do require it to be enabled, I assume that it has to do with updates, service packs, etc.)  Some versions of OSX Mail will also not require the use of outgoing authentication.
How do I set up SMTP authentication? (Outlook)
If you need assistance with any of the above, then Contact Us
jbh
Member
Hi JohnE I still can't get this to work
If 1/ were true, would the test e-mail function work? It does. I can also send messages to my own btconnect email address. Just not to others. In Outlook i get the 550 Relaying denied message. If I try to send via my iPhone I get 'The recipient was rejected by the server'
2/ I have tried with SMTP require authentication checked and un-checked. The result are the same.
JohnE
Guru
That does sound like there is a more general problem with the e-mail platform, jbh.  I'd strongly recommend that you Contact Us  We may need to carry out some troubleshooting so you can once again send e-mail successfully.
orthohin
Grand Master
Please have a look followings link..
http://www.office-outlook.com/outlook-forum/index.php/m/483473/
__________________
Orthohin
