- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, Please can you help me.
i want to use the advanced templates but i have one problem!
how do i change the txt on the flash object from saying yourcompany to my actual company name?
i have spent the last 18hrs trying to sort it on adobe c4, dreamweaver, frontpage, 3d animator, powerpoint, flashwebsite maker pro,
to be honest it doesnt tell you how to use it it just says where you find the files when you download them to filemanager on BT Website Centre.
My eyes are hurting now and it is really starting to bug me not being able to use the template with my own Name on it
PLEASE HELP ME
p.s apart from that the service is fine "please let us start using flash objects, video uploads, on easy site wizard instead of frontpage its annoying and would be easyier"
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The .swf file can't be edited.
You need to edit the .fla file that is provided then save it to .swf format. Obviously to edit this you will need a software package capable of editing flash files such as Flash or Swish.
Not sure if your existing software has this capability or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
