Announcer Pro
alexlush
Member
Not sure if this is the right place to post but here goes...
Does anyone know if its possible to add merge fields in email newsletters send by Announcer Pro.
For example, I want to use the first name and list name from my contacts list in order to personalise the email to the individual recipient.
e.g.
Hello Joe Bloggs, .... for the mail sent to [email protected]
Hello A Nother, ....for the mail sent to [email protected]
The support for Announcer seems a bit limited, any help appreciated.
5 REPLIES 5
ians
Member
I would also like to know if this is possible. Thanks.
JohnE
Guru
We supply Web tools for use by our customers as a way to get "non - professional" users going with as good looking and functional a website as possible.  It would be all too easy for us to end up designing customer's web sites for them or at least doing a substantial measure of the work.  Obviously, we can only go so far with this although we do provide a good level of support via the technical helpdesk.
Where possible we supply user guides, there is a link to the User Guide for Announcer here: What is Announcer?
alexlush
Member
Hi John,
I don't think anyone is asking BT to build our websites for us, but at the end of the day if you supply tools such as announcer pro to your customers you should be able to answer basic functionality questions such as the one I asked above.
I have assumed the answer to the original post is no, which is fine. All I was after was a Yes/No answer, and if yes, how!
The link you provided does not answer the question, in fact I'm getting a 404 error when I open the link you sent then clink the user guides link in the post. If there are more detailed user guides please let me know where they are.
Thanks.
Alex.
JohnE
Guru
Sorry about that, alexlush, here's a more direct link which may work: Announcer User Guide
Also, whilst the support we offer may be limited, depending on circumstances, we do offer support.  You can contact the technical helpdesk and you may be transferred to a specialist who will likely be able to answer your queries.
alexlush
Member
Hi JohnE,
Thanks for the updated link. I've had a quick search through the PDF and theres no mention of any merge field feature. So as I'd assumed, I don't think this is possible.
Never mind.
Cheers for your help.
Alex.
