BT Billing and migration Issue
Loggy1948
Member
How can I solve this problem with BT?
I have two lines, one of which supports broadband from Zen Internet and both of which were using OneTel/TalkTalk as a call provider.  The latter was proving expensive.
On 5th May I agreed to move all calls back to BT Business One Plan with 500 land-line minutes per line, a £200 spend commitment at £26+VAT for both lines.  I received letters both from BT and OneTel confirming this, the latter saying their service would cease unless I got in touch with them to reverse the decision, which I did not.
One of my lines was correctly migrated - ie the wholesale override was removed - but the other one was not.  Therefore the calls on this second line continued to be routed via OneTel although they had said they would no longer proved such a service.  I cancelled the direct debit to OneTel anyway.
Eventually I realised what was happening when a call I tried to make was intercepted and I complained to BT that they had not carried out the prescribed work.  As a result the second line was migrated in September but:
a) I still have a bill from OneTel for calls that should have gone via BT,
b) I have never achieved the £26.00+VAT a month from BT for both lines,
c) I have asked for the two lines to be subsumed into one bill but that has not been done and I cannot access call details online, and
d) I have used the online chat facility which managed to get the second line migrated eventually but nothing else has been done, particularly about the TalkTalk bill.  I have printouts of these chats.
So my question to the forum is:  Who in BT will actually realise that it is their mistake in the first place and take responsibility for it?  BT seems to imagine that because they did finally migrate the second line, everything is fine.  It isn't and I am being chased for a £50 bill or so because BT didn't do their job properly.  And I still want the lines under one bill at £26+VAT.
Or do I have to ask Oftel to get involved?
4 REPLIES 4
Fiona
Grand Guru
Hi
I am really sorry that you still have outstanding issues with your migration to BT Business. If you can private mail me the account details in question I can check to see if this is being looked into.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
Loggy1948
Member
The account numbers are <removed by moderator>
Sorry not to PM you - I can't where the PM facility is.  Maybe you think people only use IE.  And check the slews of javascript warnings that cause this board to be very slow but maybe that's BT's idea of customer service.
Fiona
Grand Guru
Hi
Thanks for the information. I have removed the account numbers from the post but i have a note of them. I will look over the information and see what is happening with this, then let you know.
Kind Regards
Fiona
Fiona
Grand Guru
Hi
I can see from your notes that you have contacted BT several times about this. I have collated all the information from your previous correspondence and passed this to the correct aftersales team to review it. They will investigate the issue and contact you. If you have not heard from them by the end of next week please contact me and I can see what is happening.
Sorry for all the problems
Fiona
