BT Business Hub 5 and Netgear R7000 Router configuration
craig_rich
Member
Hi all,
I have BT Business Infinity and have a Business Hub 5 as part of the package. Wifi signal is awful and I was recommended a Netgear "Nighthawk" R7000 as a decent router to pair up with the Hub. I understand that you can kill the Wifi part of the Hub 5 and essentially only use it as a Modem.
I have plugged in the R7000 "Internet" port into LAN1 on the BT Business Hub 5, fired it all up, but the R7000 says it can't find any form of Internet source. I can connect to the BT Hub via ethernet and see that it's online and connected OK. I have disabled both 2.4 and 5Ghz wifi and can connect to the R7000 wirelessly fine, but it just doesn't see any internet.
It has options to put in login name and password / ppoe etc on the Netgear. What do I put in here (if anything) ? I have taken the "[email protected]" address and password and tried that but still no go.
Any further suggestions ?
Many thanks in advance,
Craig
3 REPLIES 3
Burkem5
Guru
Hi @craig_rich
You have 3 options here,
1. You can bridge the hub 5 (disable any and all higher functions) and use the R7000 for all higher functions including PPP, DHCP, Firewall, Wi-Fi etc.
In order to do this you will need to access the Hub 5 (the default gateway should be 192.168.1.254). You can access this by connecting to the hub and typing the default gateway into your browsers address bar.
From there check that the firmware version is 4.7.5.1.83.8.200 or higher (this will be shown at the very bottom of the page)
From there you can enable bridge mode which should be under "Advanced Settings" > "Broadband" > "Routing" > Bridging= Yes"
You will then need to set up the R7000 (you will need to unplug the computer then plug in the R7000 and then reboot both)
2. You can treat the R7000 as a wifi repeater which does not require the BT hub Wi-Fi to be turned off.  This Netgear help article shows how to do this, you may want to use this in conjunction with "Powerline Adapters/ Homeplugs" to get the best coverage.
3. Improve the Wi-Fi signal on the BT Business Hub,  this can be done by looking at the available Wi-Fi channels and the signal strength of each,  Apps such as "Wi-Fi Analyzer" and "inSSIDer" will let you see which channel has the best rating.
You can then go to the router menu as explained above and then go to Wireless and change the channel to the one with the best rating.
Hope this helps
Burkem5
craig_rich
Member
Thanks very much for the reply @burkem5 - really useful. I will give it a crack tonight and let you know how I get on.
Regards, Craig
Burkem5
Guru
You are very welcome Craig,  it would be great to hear how you get on and let me know if there is anything else I can help with
