- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Simplest and quickest way is to use the spare 2700. Do not try to get them to talk to each other wirelessly - it will not work but use them in a wired config.
Connect to the the Spare2700 with your PC and access the menus.
Assuming it is a V6 go to:
http://192.168.0.1/xslt?PAGE=C_2_3
Untick the DHCP server Enabled box and then put a fixed address into the Router Address box - should be within your subnet range, but outside the DHCP range set by the primary Router 192.168.0.161 would be reasonable.
SAVE the configuration
on a V4 it is at http://192.168.0.1/xslt?PAGE=C06&THISPAGE=C01&NEXTPAGE=C06
Now you have fixed the IP address of the spare2700, disconnect the PC and connect an Ethernet cable from the Primary Router to port 1 of the spare2700.
Reconnect your PC to the normal network and in a browser access the spare2700 - 192.169.0.161
You can then set up the wireless side. Once you are happy, take the spare2700 to where it is required and connect to one of the wired outlets you have there. The 2700 will then provide wireless coverage in that area AND an additional 3 wired ports if required (IP addresses are xxx.xx.xx.141, 162, 163, 164 - 141 is V4 and the others V6)
Does it make sense?
I have a network where there is a Primary 2700 working as Modem/router/WAP and 4 further 2700s connected to the network to provide coverage in a large/difficult area.
Any questions - send me a PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does it make sense?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Excellent Posting, MHC, I'll pin this as a solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My BT set up is with a static IP address, does this change any of the necessary steps ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, I don't believe it does. You are only changing the second device which does not care what teh external IP address is - it sends all information to the gateway IP address which is within your local 192.168.xxx.xxx block and that then interfaces to the outside world.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So if I don't have a 2nd device to use, what are my options?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you wish to reliably extend wireless range, there really isn't an option beyond adding "Relay" wireless access points. Another common solution is to use "Powerline" networking, please see this explanation:
How Power-line Networking Works
Which can also be used in conjunction with additional wireless access points. Here are some examples:
BT Shop: Wireless Access Points
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
when you say set up the wireless side, do you mean set it the same as the primary hub. ie the same channel and ssid etc ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can choose to use the same SSID, encryption code &c but choose a different channel (in most cases).
I have set up some with the same SSID and code and others with different one. Sometime having several the same can cause problems especially on the PC and you may need to choose different SSIDs - can use MyNet1, MyNet2, MyNet3 &c.
If they are a significant distance apart, with no or very little overlap the same channel can be used along with the same SSIDs but if there is significant overlap then different channels can improve throughput.
Ultimately, it can be try it and see.
