BT Business One Plan Unlimited
Peach
Member
Hello, I have had Bt on to me to change from my current supplier to the business one plan unlimited, this all looks fantastic but my concern is that it is not as it seems I have 15 lines of ISDN30 will the 5000 minutes of 01,02,03 and non geo calls and 300 minutes of mobiles (less 3G) be shared between ALL the lines I.e 75,000 minutes and 4500 minutes or is it billed per Line and not shared which would be a disaster as the reality is we use lines 1-6 for outgoing calls mainly I have it in writing from BT local business that it IS shared between the lines but did a web chat with BT Business who say it is NOT shared please help as this is a big move for me Thanks John
6 REPLIES 6
Tracey
Guru
Hi Peach,
Sorry to read about the confusion.
I have looked into this for you.
Basically for the Unlimited calls package, it is £15.00 per line/channel so if you wished to have this call package on the 15 lines/channels you would have to pay for 15 call packages.
If you have the call package on one line the call minutes are only for that one line and are non transferable.
Hope this has cleared this up for you.
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
elliptical
Member
Hi,
Can you clarify that the unlimited allowance is or is not shared between the channels? I.e. most calls will be made on channels 1 & 2 and very likely to go over 5000 minutes.
Brendan
Peach
Member
Hi Brendan,
This is what I wanted clarifying as I have had BT local Business tell me it is shared between all the channels I have 1-15 making 75,000 minutes (well 70,500 as this is deducted from the total) of 01,02,03,08 numbers and 4,500 minutes of Mobiles (excluding 3G and Dolphin)
However BT Business have told me that is NOT shared between the channels and they are PER LINE, making 4,700 minutes and 300 minutes respectively per Line
As you quite rightly point out most of our calls will be Lines 1-6 maximum as this is how most Telephone Systems are programmed and so on that basis it would not be worthwhile changing from my existing supplier
I am told by a friend that BT Local Business do not care whatever they tell you as they do not bill you - it becomes BT Business problem from a billing point of view and I do not want to be tied into a 2 year contract without complete clarification (T's and C's from BT which I cannot find anywhere)
I feel there is a lack of clarity from BT and is further confused on this forum as Tracey a BT Forum Moderator is quoted below
Hi Peach,
Tracey
BT Forum Moderator
This reads to me that the inclusive plan is PER LINE or CHANNEL although not conclusively and yet in a forum post further up the page Chris3p who is a BT Partner states the following
I should also mention that the Unlimited deal is subject to a Fair Usage Policy. This translates to 5,000 fixed line and international minutes per month and 300 fixed line to mobile minutes. If you have the package on a multi-line installation (using the example I made in my post above) this "allowance" is multiplied by the number of subscriptions you have e.g. 20,000 fixed and international minutes and 1,200 fixed to mobile minutes.
I would just like someone to point me to the Terms and Conditions that define exactly what the situation is - Are these minutes per Line/Channel and billed as that or shared over the Lines/Channels the customer has
Any help would be appreciated
Cheers
John
325consultancy
Member
Hi,
Hope this clarifies...The shared minutes depend on the type of lines you are using (individual or Auxillary)
Are the 500 free minutes, and the Unlimited Calls Packages, line based, or shared by site or customer level?
The Free Minutes and the Unlimited Calls Packages are applied per line or installation (where applicable) and are not
transferable to other lines outside of that installation.
Every eligible fixed line in the customer’s One Plan Inclusive inventory receives the 500 Free minutes. The Unlimited
Calls Package is opt in and has to be taken at “installation level” – so all lines sharing the same telephone number
(auxiliary lines) must also take the Unlimited Calls Package and pay the Unlimited Calls Package charge.
The Unlimited Calls Package has to be taken at installation level - so all lines/channels sharing the same telephone number (auxiliary lines) have to take a package and pay the fee. However, monitoring of the Fair Use Policy is also at installation level. Each calendar month BT adds together the allowance per line in the installation (“total allowance”) and the usage across all the lines in the installation (“total usage”). Where the total usage exceeds the total allowance BT will commence charging for additional calls on all lines in the installation from the next calendar day.
Keeping the maths simple - if I had three lines (1 + 2 aux) on a £500 One Plan Inclusive and wanted to take the Unlimited Calls Package:
I'd have to have 1 per line = 3 and pay 3 x £15 = £45 per month Fair Use Policy allows up to 5000 inland/idd fixed minutes and 300 f2m minutes This gives me 15,000 inland/idd mins and 900 f2m mins across my installation (3 lines) per month It does not matter whether each line uses them equally, or one line uses all of them. So line 1 could exceed 5000 inland/idd minutes but would not be charged for additional calls if the total for the installation had not reached 15,000
This is not the same if I had 3 separate telephone lines, on separate numbers/installations:
In this instance I could pick whether to have packages on any line but would not have to have on all three if I did not want to Fair Use Policy allows up to 5000 inland/idd fixed minutes and 300 f2m minutes - but this is measured at installation level, so in this example it applies on a line by line basis (there is no "pooling") If any individual line/installation with an Unlimited Calls Package exceed the Fair Use Policy they would be charged from the next calendar day - even if other lines/installations had not reached their FUP.
Happy to speak to ypu directly if required. PM your contcat information and I will 'phone you
Best Regards,
Karen
Karen Rogers | Account Manager | 325Consultancy | Telecom & IT services
Email:
karen@325consultancy.com
Phone:
+44 (0) 844 736 2675 ext 2676
Web:
www.325consultancy.com
Fax:
+44 (0) 844 736 2614
This communication together with any attachments transmitted with it ("this E-Mail") is intended only for the use of the addressee and may contain information which is privileged and confidential. If the reader of this E-Mail is not the intended recipient or the employee or agent responsible for delivering it to the intended recipient you are hereby notified that any use, dissemination, forwarding, printing or copying of this E-Mail is strictly prohibited. If you are not the intended recipient, be advised that you have received this email in error and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. Please then immediately delete, erase or otherwise destroy this E-Mail and any copies of it. If you have received this email in error please contact the sender.
Although we have taken steps to ensure that this e-mail and attachments are free from any virus, we advise that in keeping with good computing practice the recipient should ensure they are actually virus free.
Any opinions expressed in this E-Mail are those of the author and do not necessarily constitute the views of the Company. Nothing in this E-Mail shall bind the Company in any contract or obligation.
For the purposes of this E-Mail "the Company" means 325 Consultancy.
frankwills34
Member
We offer a range of calling plans that give you great savings on your calls. We have a plan to suit your needs whether you have just a land line or you have a range of services with BT. Choose from one of the options below to see which calling plan is best for your business.
 Want to get-on Google's first page and loads of traffic to
your website? Hire a SEO Specialist from Ocean Groups
[url=http://oceangroups.org/] seo pecialist [/url]
MGBTLB
Member
