BT Home Hub DNS Issues with cctv system
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi Everyone,
I have a CCTV security System connected to bt home hub (white w/phone) ,I have set up a dns address
@ dyndns.com,the problem is the dynamic address is not being updated on router so i cant log in to view
cctv,the pc is off most of the time,but apparently this router has an in built updater,does this need to be activated/enabled??
any help would be appreciated...I have set up port forwarding etc. and i have accessed when originally set up( before ip address changed!!)
0
Kudos
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
mikecctv,
yes you will need to enable dynamic DNS on the hub. Go to Advanced, then click Continue to advanced:. On the extended menu at the left under configuration click Dynamic DNS at the bottom and you'll be able to enter your DynDns details in there.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you please advise how to configure dynamic DNS on homehub 3.
Your assistance would be much appreciated.
Regards
Alan
0
Kudos
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You may find the help you require over at the Residential forums:
BTCare Community Forums
It's probably the best place to get advice about setting this up on the Home Hub.
0
Kudos
