So I was trying to get into streaming some gaming and aplications using OBS on picarto and twitch.
However whilst the audio is fine on my stream the video and image lags and stutters very very badly.
I tried contacting BT but they only deal with download problems. Someone please help me!!
Bt infinity 2
bt hub 3
Macbook Pro
1. Product name: | BT Home Hub |
2. Serial number: | +058720+1124043597 |
3. Firmware version: | Software version 4.7.5.1.83.8.94.1.37 (Type A) Last updated 18/03/14 |
4. Board version: | BT Home Hub 3.0A |
5. WAN: | PPP Connected |
6. Data sent/received: | 2.8 / 2.8 |
7. Broadband username: | bthomehub@btbroadband.com |
8. BT FON: | Yes |
9. Wireless network/SSID: | BTHub3-P6KF |
10. Wireless connections: | Enabled, (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled |
11. Wireless security: | WPA and WPA2 |
12. Wireless channel: | 9 |
13. Firewall: | Default |
Did a BT Engineer connect you to Infinity? We've just been upgraded to BT Infinity and to take full advantage of it I believe you need the BT Home Hub 5. We used to have a 3 but the engineer said it wouldn't work with Infinity so we now have a Hub5 dual band.
