Hi,
I set myself a BT PC Fax account, but cannot for the life of me remember what the number was I had set up.
Is there any way I can retrieve this number?
Cheers,
Tom
Solved! Go to Solution.
Hi TomKelly,
You would need to speak to the Technical Team who would be able to assist you with the log on details.
These would need to be double checked.
Hope this is of help
Tracey
BT Forum Moderator
Hi Tom,
When did you set up your account?
Tracey
BT Business Forum Moderator
Would have been about 1 month or so ago.
Hi TomKelly,
You can retrieve your log on details by logging into the BT PC Fax Login page
Once you are logged in there you will be able to see all your account details.
Hope this helps
Tracey
This is beyond a joke now.
I set up a different account, on a different email address. I received my password, I have my username, but I am now being told to "check that you entered your username and password correctly"
I am copying and pasting the details from the email, so they cannot be wrong!
Hi TomKelly,
Tracey
BT Forum Moderator
They just told me to email "pcfax@btpcfax.co.uk"
I have sent countless emails to this address, and still have not received 1 reply!
Hi TomKelly,
I am really sorry that you haven't had a reply as they are normally very quick to respond to the emails.
Im afraid you would need to try emailing them again.
Tracey
BT Forum Moderator
