BT Versatility line forwarding/divert when no aux present
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I am working on an BT versatility system, have 4x V8 featurephone handsets and 2x CO lines (one of which had an AUX in the past) and everything is working OK, however, the customer has changed from BT to another company for their phone service, in doing so they have lost the aux line of the main number, now they only have one CO line for their main number and a separate line which they use for ADSL broadband (Whic is still with BT on an 2700 router)... Im not sure at this stage if the new company (O2) can supply them with an aux on the main line, however, for the moment is their a way in which I can 'trip' the main line to the broadband line on busy... If i understand correctly, this will not happen automatically since i am not dealing with ISDN or AUX lines... is it possible through the Versatility to set up an auto divert or forward, if as busy tone is recieved on the main line?... i understand this may be a chargeable divert but thats not a problem for the moment.
Secondly, The customer is using Auto Attendant at the moment, however, for some reason incoming calls will flash red on line 1 LED but no sound can be heard on the handsets... but on internal calls ringing can be heard, also, if i set the incoming ringing option in the menu to Extension or Group then the phone will ring audibly. Any ideas how to get around this one?....
Many thanks
Adam
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I'm sorry no one on the forum has been able to help with this query.
If you have a maintenance contract for BT Versatility you can get help from their online support. If you don't have a contract you can sign up for one here.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We have just moved and have installed the system in the new building. We had the lines connected to the correct specification and have a problem with line 2 and 3 we have 4 incoming lines and can only get two lines on line 1 and 2, 3 and 4 do not have any dailing tone on them. what should I do? Bt have checked the line and there was a problem but they have fixed it but the problem remains the same.
everything is installed correctly. when people call in there are aonly 2 lines working on the system. HELP
Brett
