BT2700HGV error message - unable to sync data
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all,
I've noticed that I'm getting a vast number of warning messages in the BT2700HGV System Log, as follows:
WRN 2010-09-13T12:17:25+01:00 nodesd: unable to sync data: No such file or directory
WRN 2010-09-13T12:41:18+01:00 nodesd: Previous log entry repeated 20280 times
Has anyone else experienced this, and know what to do? It seems to be trying to contact a server somewhere at least 30 times a second - this seems madness!
Performance is not as good as it used to be, so I'm not sure whether this might be having an adverse effect.
Any suggestions?
Thanks,
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think it's an issue where the network table is failing to update. How many PC's do you have on the network? Can you also check Settings> Private Network> Statistics, under Private Network DHCP Info it should display how many Remaining DHCP slots you have. Could possibly be caused by a saturated DHCP table, you can either clear the device list or lower the DHCP timeout to 2hrs or so.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the suggestions.
I've only 3 PCs on the network, currently it's showing DHCP slots as Allocated:7, Remaining:183, so that doesn't seem to be an issue.
Any other ideas? Latest entry in the system log is showing the error "Previous log entry repeated 581643 times" !!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Peter, would you be able to PM me the serial number of your router and i'll see if I can gather more data to try and track down what's causing the issue?
