I am losing the will to live with what is barely better than old dial up. We moved into an office last week and eventually got line setup and broadband. Decided on BT as we though this would be painless. But this is terrible. See below.
Seems our UP link is faster than DL?!
Any ideas/help? No extenison sockets, BT filter used etc.
DSL Details
| Modem Type: | Built in modem - ADSL | |
| DSL Line (Wire Pair): | Line 1 (inner pair) | |
| Current DSL Connection: | ||
| Down Up | ||
| Rate: | 294 kbs | 684 kbs |
| Max Rate: | 205 kbs | 1096 kbs |
| Noise Margin: | 4.5 dB | 5.7 dB |
| Attenuation: | 63.0 dB | 37.2 dB |
| Output Power: | 12.4 dBm | 12.2 dBm |
| Protocol: | G.DMT2+ Annex A | |
| Channel: | Interleaved | |
| DSLAM Vendor Information | Country: {46336} Vendor: {TSTC} Specific: {4101 } | |
| ATM PVC: | 0/38 | |
| Rate Cap: | 205 kbs | |
| Attenuation @ 300kHz: | 63.0 dB | |
| Uncanceled Echo: | -21.4 dB | Ok |
| VCXO Frequency Offset: | -48.8 ppm | Ok |
| Final Receive Gain: | 29.9 dB | Ok |
| Excessive Impulse Noise: | 0 | Ok |
Traffic Statistics
| IP Traffic | Bytes Packets Errors %||||
| Transmit: | 62089592 | 45 | 0 | 0 |
| Receive: | 1119059169 | 4551388 | 0 | 0 |
| ATM Traffic | Cells Errors %||||
| Transmit: | 191446058 | 0 | 0 | |
| Receive: | 27862491 | 0 | 0 |
DSL Link Errors
Collected for 3Days23:36:17
| Since | Current | Current | Time Since | |
| Reset 24-hr int. 15-min int. Last Event | ||||
| ATM | ||||
| Last Event | ||||
| Cell Header Errors | 382 | 89 | 2 | 0:03:15 |
| Loss of cell Delineation | 206 | 34 | 2 | 0:03:15 |
| DSL | ||||
| Link Retrains: | 0 | 0 | 0 | 0:00:00 |
| DSL Training Errors: | 1 | 0 | 0 | 3Days23:36:05 |
| Training Timeouts: | 0 | 0 | 0 | 0:00:00 |
| Loss of Framing Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Signal Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Power Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Margin Failures: | 0 | 0 | 0 | 0:00:00 |
| **bleep**. Seconds w/Errors: | 376 | 82 | 2 | 0:01:14 |
| **bleep**. Sec. w/Severe Errors: | 0 | 0 | 0 | 0:00:00 |
| Corrected Blocks: | 15113382 | 3974147 | 21871 | 0:00:01 |
| Uncorrectable Blocks: | 637 | 161 | 4 | 0:01:14 |
| DSL Unavailable Seconds: | 29 | 0 | 0 | 3Days23:35:47 |
Sorry to hear that bud. Is this a shared connection? Try this step to isolate the issue.
1. Direct connect a single laptop to the BT modem.
2. Run 2 commands. "traceroute google.com" and "pathping google.com"
Those command will show you which hop if in the network side is causing you problems and you can probably submit a ticket to BT support to have it investigated. If you are having problems to the gateway, then there's clearly a line problem there.
Good luck.
The attenuation figure is high and could well be a lot greater. How far are you from teh exchange? Both as te crow flies and to drive - it will not give an exact length of te line but will be indicative.
Hi nikkil, thanks I will contact BT.
MHC we are apparently 3km from the exchange.
I'll have to resort to working from home again soon!
@dazzling wrote:Hi nikkil, thanks I will contact BT.
MCH we are apparently 3km from the exchange.
If you are 3 km from the exchange - actual route then the attenuation is way too high. I would expect around 40dB at that distance.
Can you try the little checker at: http://bbcheck.co.cc/ It does not store any data and take a few seconds find teh line details. Then just post the:
Recorded Line Length: 3123m
Estimated Attenuation: 43dB
details here.
Thanks for that!
Well.....One site told me 3K but I am further than that:
Phone number checked: 0161474****
Postcode checked: Sk57bw
Data found:
Exchange: Stockport
Recorded Line Length: 4403m
Estimated Attenuation: 61dB
You are connected to one of the following:
Cabinet 55 which is currently planned to receive FTTC (50% of lines)
Cabinet 91 which is currently planned to receive (50% of lines)
No speed estimate is currently avaiable for your line.
a 294k sync speed is still low ... the atteniuation is about right but an ADSL2+ line should be able to give better speed than that.
I have sent you a PM.
