Broadband loss in the evenings
RuthD
Member
Our office broadband is in a fairly rural area.  Acceptable speed in the daytime, but working online in the evening is impossible.  Wired network - quiet line test OK - filter makes no difference - no issues on exchange (Horsley EMHORSL) or in area.  It's just the evenings.  Is there anything I can do? 192.168.1.254 gives the following (however this is 4pm - I can't do this in the evening because no connection):-
DSL Details
Down Up
Modem Type:Built in modem - ADSL
DSL Line (Wire Pair):Line 1 (inner pair)
Current DSL Connection:
Rate:4384 kbs933 kbs
Max Rate:5369 kbs928 kbs
Noise Margin:5.8 dB5.5 dB
Attenuation:48.9 dB27.8 dB
Output Power:19.5 dBm12.5 dBm
Protocol:G.DMT2 Annex A
Channel:Interleaved
DSLAM Vendor InformationCountry: {46336} Vendor: {IFTN} Specific: {51313 }
ATM PVC:0/38
Rate Cap:5369 kbs
Attenuation @ 300kHz:48.9 dB
Uncanceled Echo:-23.8 dBOk
VCXO Frequency Offset:-59.3 ppmOk
Final Receive Gain:24.4 dBOk
Excessive Impulse Noise:0Ok
Traffic Statistics
Bytes Packets Errors %Cells Errors %
IP Traffic
Transmit:4401218000
Receive:69997471800
ATM Traffic
Transmit:256800
Receive:1500900
DSL Link Errors
Collected for 0:02:22
Reset 24-hr int. 15-min int. Last Event
 SinceCurrentCurrentTime Since
ATM
Last Event
Cell Header Errors0000:00:00
Loss of cell Delineation0000:00:00
DSL
Link Retrains:0000:00:00
DSL Training Errors:1110:02:03
Training Timeouts:0000:00:00
Loss of Framing Failures:0000:00:00
Loss of Signal Failures:0000:00:00
Loss of Power Failures:0000:00:00
Loss of Margin Failures:0000:00:00
**bleep**. Seconds w/Errors:0000:00:00
**bleep**. Sec. w/Severe Errors:0000:00:00
Corrected Blocks:2929290:00:03
Uncorrectable Blocks:0000:00:00
DSL Unavailable Seconds:3636360:01:45
1 REPLY 1
markp
Grand Guru
Hi RuthD
What I would advise is to contact the helpdesk on 0800 800 154 when you loose connection to get them to run tests on the line to see if there is anything affecting the line at that time of day.
Markp
