Had an open reach enginner out been on the phone many times and i am getting really high **bleep**. Seconds w/Errors: and Uncorrectable Blocks: and Cell Header Errors they have also capped my rate down and the speed has decreased dramiticaly
the intial problem was losing connection which now seems to be stable but my broadband has really slowed down.
please help !!!!!!!!!! you can see what is happening for being connected for 1 hour 48mins
DSL Link Errors
Collected for 1:48:09
Since | Current | Current | Time Since | |
Reset 24-hr int. 15-min int. Last Event | ||||
ATM | ||||
Last Event | ||||
Cell Header Errors | 708 | 708 | 10 | 0:01:01 |
Loss of cell Delineation | 0 | 0 | 0 | 0:00:00 |
DSL | ||||
Link Retrains: | 0 | 0 | 0 | 0:00:00 |
DSL Training Errors: | 0 | 0 | 0 | 0:00:00 |
Training Timeouts: | 0 | 0 | 0 | 0:00:00 |
Loss of Framing Failures: | 0 | 0 | 0 | 0:00:00 |
Loss of Signal Failures: | 0 | 0 | 0 | 0:00:00 |
Loss of Power Failures: | 0 | 0 | 0 | 0:00:00 |
Loss of Margin Failures: | 0 | 0 | 0 | 0:00:00 |
**bleep**. Seconds w/Errors: | 1539 | 1539 | 26 | 0:00:08 |
**bleep**. Sec. w/Severe Errors: | 0 | 0 | 0 | 0:00:00 |
Corrected Blocks: | 0 | 0 | 0 | 0:00:00 |
Uncorrectable Blocks: | 2293 | 2293 | 30 | 0:00:08 |
DSL Unavailable Seconds: | 0 | 0 | 0 | 0:00:00 |
Please post some line details. ie. current downstream line speed/rate, noise margin, protocol, channel as reported on same page where you obtained the DSL error stats.
Looks like your line is configured for non-interleaved (Fast) connection, as it is reporting uncorrecctable blocks. ie. the blocks are being resent when an uncorrectable (corrupted) one is received.
Over the 1h48m, the stats look okay for a slightly noisy line. Monitoring over a longer period such as 24 hours would be more useful.
If you have the old NTE5 single outlet master phone socket, I presume you have gone through the steps of connecting the hub directly to the test socket to eliminate problems which may be caused by your internal phone wiring.
Fault testing with master socket
This is an overnight report they were trying to put 24mb down the line which it could not handle DSL Details
Modem Type: | Built in modem - ADSL | |
DSL Line (Wire Pair): | Line 1 (inner pair) | |
Current DSL Connection: | ||
Down Up | ||
Rate: | 2006 kbs | 811 kbs |
Max Rate: | 1985 kbs | 832 kbs |
Noise Margin: | 6.7 dB | 6.8 dB |
Attenuation: | 48.1 dB | 23.5 dB |
Output Power: | 16.7 dBm | 12.3 dBm |
Protocol: | G.DMT2 Annex A | |
Channel: | Interleaved | |
DSLAM Vendor Information | Country: {46336} Vendor: {IFTN} Specific: {48753 } | |
ATM PVC: | 0/38 | |
Rate Cap: | 1985 kbs | |
Attenuation @ 300kHz: | 48.1 dB | |
Uncanceled Echo: | -28.7 dB | Ok |
VCXO Frequency Offset: | -40.3 ppm | Ok |
Final Receive Gain: | 23.9 dB | Ok |
Excessive Impulse Noise: | 0 | Ok |
Traffic Statistics
IP Traffic | Bytes Packets Errors %||||
Transmit: | 1646738 | 41 | 0 | 0 |
Receive: | 14472037 | 14271 | 0 | 0 |
ATM Traffic | Cells Errors %||||
Transmit: | 611329 | 0 | 0 | |
Receive: | 1843076 | 0 | 0 |
DSL Link Errors
Collected for 21:32:53
ATM | ||||
Last Event | ||||
Cell Header Errors | 8679 | 8679 | 0 | 1:27:08 |
Loss of cell Delineation | 239 | 239 | 0 | 1:27:08 |
DSL | ||||
Link Retrains: | 3 | 3 | 0 | 1:27:08 |
DSL Training Errors: | 67 | 67 | 0 | 1:24:31 |
Loss of Framing Failures: | 6 | 6 | 0 | 1:27:08 |
Loss of Signal Failures: | 6 | 6 | 0 | 1:27:08 |
Loss of Margin Failures: | 6 | 6 | 0 | 1:27:08 |
**bleep**. Seconds w/Errors: | 15899 | 15899 | 0 | 1:27:08 |
**bleep**. Sec. w/Severe Errors: | 7 | 7 | 0 | 1:27:08 |
Corrected Blocks: | 18985 | 18985 | 533 | 0:00:00 |
Uncorrectable Blocks: | 26049 | 26049 | 0 | 1:27:08 |
DSL Unavailable Seconds: | 921 | 921 | 0 | 1:24:13 |
this was in the test socket which is brand new
Looks like interleaving may have perhaps been turned on earlier this morning as the stats are now reporting 'Corrected Blocks'. (aka FEC). I presume the 'Uncorrectable blocks' has stopped incrementing this morning?
If you examine the following page on your hub:
Settings, Diagnostics, DSL
Under Training History section.
It should list all previous disconnections, line speeds etc. Examine whether the protocol (mode column) has changed too overnight.
Look at the column labelled 'Mgn1' for the very last line entry (representing the line stats at the time you opened the page). This should give you the 'target' noise margin at the start of the current connection. What is the value? around 6.0 by any chance?
With a line attentuation of 48dB and 6db noise margin, a downstream line speeds of 4 to 7mb should be possible on a 'good' line.
The current 2006kbps downstream rate does seem unusually low unless your line is inherently 'Very Noisy', or it is still undergoing line training.
Your line appears to be configured for upto 12mb 'ADSL2' (G.DMT2 annex A) service, and I notice the upstream rate is higher than normal, currently 811kbps. It is usually around 445kbps.
Unless you specifically requested the higher upstream rate, I would speak to BT about getting it lowered. It may possibly help to raise the downstream speed but don't quote me.
Changing the protocol to the 'upto 8mb' 'ADSL1' (G.DMT annex A)service is another option but I can't see the downstream speeds increasing by a factor of 2 or 3 by doing so TBH, but it may improve stability.
Hi there correctable blocks still rising as we speak and you were bang on the noise margin is 6.0 BT is organising go get the line card swapped hopefully this will sort out my problems
Rising corrected blocks is perfectly normal and nothing to worry about. It is a function of having an interleaved connection.
Has the 2wire hub been previously replaced in case it is perhaps faulty?
Looks like a line problem to me. You should contact support, have it tested remotely.
They should be able to send a technician on there own if it's really necessary and proved to be a line problem. Cheers!
Engineer been out and hopefully touch wood things seem to have settled down but really weird thing
is with the business hub 2701 connected and run a speed test i get 1.6mbps connect a bt home hub 3 run the same test and i connect at 2.8mbps also the upload speed goes up both hubs are correctly configred with my account details etc Makes me wonder if i should bin the bt equipment and buy my own
