Broadband works with ethernet, but not wireless
SueM
Member
When I first connected my broadband, both the ethernet and the wireless worked. The (small) comuter network is attached to the ethernet, and my phone could use the wireless.
Now my phone doesn't find the wireless. Its's not a fault with the phone - it finds myriad other wireless connections in this area.
Is this likely to be a problem with the hub? What can I do?
1 REPLY 1
adrianc
Master User
Hi Sue,
Yes, it does sound like it's an issue with the hub - if it's a BT hub then have a look at this article and see if it helps.
Adrian
