Business Hub - Modem Only Mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
The problem we're having is the Internet keeps dropping out with the zyxel, but when trying the business hub, there are no problems. All firmwares are up to date.
So...my question is, can we use the modem only in the business hub and keep our current network setup as it is with the ZyXEL? If not, I'm guessing we'll just need a new router?
Many thanks 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Set up the BT hub in bridge mode ... then do everything else on te ZyXEL.
Go to the hub ... HOME and then to page: home/xslt?PAGE=C_1_1 and it is at the bottom of the page.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi. I thought he wanted to make the BT hub as modem. I'm confused since bridge mode is different from modem mode. Please correct me if I'm wrong.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@mithcd wrote:Hi. I thought he wanted to make the BT hub as modem. I'm confused since bridge mode is different from modem mode. Please correct me if I'm wrong.
You obviously know so much, why not give a solution instead of continually posting pointless useless posts.
For the benefit of the OP, selecting bridge mode disables all routing, NAT and DHCP in the hub and provides a single output from the modem stage - the fixed and unchangeable IP address is: 192.168.1.254
