Solved! Go to Solution.
I think there's some misinformation here. BT shares it's Retail Broadband Network at the national level between business and consumer broadband users. In the business day, very few consumers are online so business gets pretty much the full capacity. Since consumers heavily outnumber business users this allows really good business response throughout most of the business day. As consumers start using the service - starts picking up from 4pm - the network gets busier. It's congestion, rather than active shaping.
Contention ratios at the exchanges went out years ago. The key change was the increase in capacity of the circuits between exchange and core network. This effectively removed the bottleneck and the need for contention ratios. So it doesn't matter from that point of view.
Of course, there's always the chance that you get local interference from 4pm ish. The consumer traffic build should be gradual. If your speed goes off a cliff it might be interference of some sort.
....if I had a fiver for everytime I heard that 😛
On a serious note though, I share your frustration! I'm actually using my neighbours connection (with their permission) to write this, as I haven't even got enough bandwidth to open this page. My average download speeds around half 8 are between 512 bytes and 5kbs!
Roll on end of the contract tbh!!
its maybe not traffic shaping. its probably those dam kids coming home from school.
all kids do o nowadays is go on the internet for youtubing msning and some even play games over t'internet.
It's not caused by youtube from my end as there is only one machine connected and it's only used to view CCTV at a property.
Both connections are mine, the sending connection is be with a 2.5 upload and the BT connection is fine until 4pm and them it recovers at some point between 11pm and 1am.
like i said. dam kids.
wasnt meaning you youtubing etc, i meant the kids
is your premises near a residential area?
ps. does it also do this on a saturday or sunday?
Yes the area is pretty residental, I thought via contention business connections take a higher priority?
Yes when it hits 4pm on Friday the connection is unusable until Monday morning.
The application I use shows the rate, during the day its always around 2250kbps but come throttle time its anything between 0-500 which obviously makes the video unstable.
single broadband packages have a 50 - 1 contention ratio.
residential is probably 100 - 1
theres a chance that the exchange is being drained by the residential folk as even though they are on a different part of the exchange it'll still be the same exchange.
or
you've been put on a residential section or have a residential BRAS profile. something silly like that.
ah. now thats a tough one.
gonna have to be a call to FL tech support. check if your traffic shaped already and if not its a fault. notes should be included by tech support to say its from 4pm onward
Thanks for the reply,
I have instead sent an email to the cceo and had a reply back from an adviser saying they will call back this afternoon.
Whats interesting is no BT support staff on this forum have replied...
