Can I divert calls to a mobile from Marquis II system?
slummy71
Member
I work in a building which uses a Marquis II phone system from BT. (it is very old...) I know how to divert incoming calls from the main handset to extensions but wondered if it is possible to divert calls to a mobile? We don't want to upgrade the system as we are moving to new premises next year but would like to be able to move around the building without missing calls in the meantime. I have phoned BT but they don't seem to be able to help as they don't have any information about this system. Any help would be appreciated.
S
1 REPLY 1
Davel
Super User
Not familiar with this system but I assume you dial 9 for an outside line. If this is the case and you have Star Services on your line it is simple. So to divert all calls, press 9 for an outside line, then *21(number to divert to)# and to cancel divert
#21#.     If you google BT Star Services you will find a full list of various diverts etc.
  If you want to "transfer" an incoming call to a mobile, this is not possible as trunk to trunk transfer is not a facility on older systems.
