Can I set a specific Broadband network IP address?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all,
I want to be able to have the same public IP address I recently used (86.xxx.xx.xx).
When I go into the BT HH Manager and Disconnect then Reconnect the internet it gives me a new public IP.
The last 5 I was given are ; 86.147.126.98, 86.145.154.183, 86.145.129.79, 86.145.132.182, 86.145.130.116.
It's probably impossible for me to get the same IP by Disconnecting then Reconnecting my internet.
Is there any way I can force the Hub to give me the IP I want (as long as it isn't already in use)?
Thanks in advance,
Jamie
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, you cannot force the IP address - they are dynamic and you will be allocated the next in the stack.
However, if you request a STATIC IP address as part of your package then you will be allocated an address and it will never change.
But, I notice you are using a Home Hub - whether or ot residential customers can get a static IP address, I do not know and you will need to call the BT orders/sales team to find out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Static ip addresses are not provided by BT residential, you can request one from BT business at £5 per month. As long as the home hub you are using is version 2 or above I believe this is compatible with business lines.
Thanks,
Steve
