Cannot create a rule using Outlook 365
mikej101
Power User
Cannot create a rule using Outlook 365 - when I try to apply the rule I want it reports that I am not authorised to do it ? Why? The exact message is that 'I don't have permissions to update the specified option' - Why not ?
1 REPLY 1
markp
Grand Guru
Hi mikej101,
With Office 365, to be able to create rules through the website you need to have Office 365 for small buinsess or Premium. If you only have Office 365 lite the option to create rules is there but as it is not the full version of Office 365 you are not able to make the rule active.
Markp
