Changing template size
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I've just knocked up a website using the BT easy site wizard and one of the templates. My question is - can I change the size of the panel in the middle of the screen where all the text and pictures are? Just like this (BT forum) site there is the white background and the panel in the middle of the screen where all the text and pictures are. I'd like to be able to put more info on my site and have to scroll down to see it. Unfortunately it is just the small panel in the middle of the screen.
Any ideas on how I can do this.
Many thanks
0
Kudos
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Depending on the template size you should be able to increase the size of the "working area" for lack of a better term by trying to move a picture or text box beyond the bottom of the editor. Usually this causes the scroll bar to appear on the left and gives you more space to work with. The actual backgrounds may not increase in size this way but depending on the template this may work for that as well. If not you can often choose the panel you are referring to as if it were a picture and increase it in the same way you would increase the size of a text box or picture. That is to say by double clicking it and dragging the white boxes around the outside of the square. Hopefully one of these options work for you.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you very much.
I was able to drag the working area down but not width ways which is better than nothing.
Cheers
