Configuration BT Hub For Broadband Voice.
sdon
Member
I am trying to Configure hub for voice and follow on the on screen details,I enter admin for user name and Serial number on Hub into the box on the screen and get a message stating 400 bad request.
No phone light on hub.
How do I manual set up the hub.
I have email BT Broadband voice help desk but NO reply.
Any help around guys.
1 ACCEPTED SOLUTION
Accepted Solutions
SeanC
Master User
Hi Sdon
This sounds like the username or password could be wrong, if the password has not been changed then try adm as username.
If you are still having problems send me a private mail with your voip details plus contact name and number.
Regards
Sean
View solution in original post
6 REPLIES 6
325consultancy
Member
Hi,
It sounds like your number has not been activated as yet;  If it was the light would be a steady blue..
Login at www.bt.com/bbt - You will need your broadband voice/talk number and the password that you would either have been sent via email or post.  Once you have registered you should then be able to follow the normal steps.
If you need a user guide PM you email address and I will be happy to send it to you
Karen
Karen
Karen Rogers | Account Manager | 325Consultancy | Telecom & IT services
Email:
[email protected]
Phone:
+44 (0) 844 736 2675 ext 2676
Web:
www.325consultancy.com
Fax:
+44 (0) 844 736 2614
This communication together with any attachments transmitted with it ("this E-Mail") is intended only for the use of the addressee and may contain information which is privileged and confidential. If the reader of this E-Mail is not the intended recipient or the employee or agent responsible for delivering it to the intended recipient you are hereby notified that any use, dissemination, forwarding, printing or copying of this E-Mail is strictly prohibited. If you are not the intended recipient, be advised that you have received this email in error and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. Please then immediately delete, erase or otherwise destroy this E-Mail and any copies of it. If you have received this email in error please contact the sender.
Although we have taken steps to ensure that this e-mail and attachments are free from any virus, we advise that in keeping with good computing practice the recipient should ensure they are actually virus free.
Any opinions expressed in this E-Mail are those of the author and do not necessarily constitute the views of the Company. Nothing in this E-Mail shall bind the Company in any contract or obligation.
For the purposes of this E-Mail "the Company" means 325 Consultancy.
sdon
Member
The hub will not configure after inputting admin and password,I get a message stating 400-Bad Request.
sdon
Member
Well called BT today with no joy,got sent to a far away place.Reading from the cards.
STILL not working.
Going to call soon and cancel the voip call.
Is there a BT help desk in the UK that can help ?
SeanC
Master User
Hi Sdon
Regards
Sean
sdon
Member
Sean,
Thanks 'ADM' worked,BT should update the help site with that,because it states 'ADMIN' and password.
Thanks again.
Steve
SeanC
Master User
Hi Sdon
Glad that helped you get passed Smiley Wink the adm user name was only for the first batches of the 2701's this is corrected for the latest batch and admin should work fine.
Regards
Sean
