Hello
I have just had BT Business Total Broadband activated. I didn't order a new router as I plan to use my BT Home Hub. I'm having problems connecting the 2 and can only manage it by using the ethernet wire. I have been give the details I need in my welcome letters to change the router settings but can;t access them. Of course, if I disconnect the ethernet cable then I can't connect to the homehub settings page at all. If its connected, then it tells me that no changes are necessary as its already set up.
Any help would be appreciated.
Many thanks
Hi UpsyDaisy,
Sorry to read about the problems that you have been having.
Hopefully another forum member will be able to help you out with this, if not our technical support team will be able to assist (0845 600 7020 opt 2).
Tracey
BT Business Forum Moderator
