Hi,
I'm having a problem adding a link from a smaller image on my web page to allow a larger picture to open as a separate page. I'm using Easy Site Wizard.
I've tried adding on image properties the http address of my website/image title, but although the new window opens, a message comes up with unable to find web page.
Any help would be appreciated
Kimi
Solved! Go to Solution.
It should work if you create a hyperlink to the following, substituting the obvious parts for your own details:
http://www.yourdomain.com.com/ESW/Images/filename.jpg (may also end with .gif or .png depending on the image type)
