Default Admin password
brupavuclo
Member
Hi I am after some help. I set the Skype download content filter to stop my kids surfing 24/7. They wrote down the default password off the side of the Hub and can use that as a master password. Is there anyway I can reset that password.
2 REPLIES 2
MHC
Guru
Go to:  http://home/xslt?PAGE=C_0_1    It will need your default password which is te router serial number and then you be given an option to change the password.
It will not stop them using the <I forgot psssword> button or a hard reset but at least you will know if they have done that.
kimura
Super User
How is this working for you so far brupa?
